Top 250 | 18 MHz | UTC | Spotter | Comment |
TL7M | 18071.0 | 03 Nov 06:46 | PA0VLY | 1.5 up. Tnx qso |
RA9CUU | 18100.0 | 03 Nov 06:32 | SP5MXG | FT8 -09dB from MO17 1239Hz |
RW0UM | 18100.0 | 03 Nov 06:22 | RV0APH | FT8 |
TL7M | 18071.0 | 03 Nov 06:10 | IZ2KPE | up 1. only ja :-((( |
TL7M | 18070.9 | 03 Nov 06:03 | RA0FF | QSX 18072.00 |
5Z4VJ | 18101.7 | 03 Nov 06:01 | UA9LCY | Tnx for qso |
R0AY | 18100.0 | 03 Nov 05:52 | UX1HP | KN68UX<>NO76 |
JA7AXP | 18100.0 | 03 Nov 05:50 | UX1HP | KN68UX<>QN00IT |
RW0UM | 18100.0 | 03 Nov 05:46 | UX1HP | KN68UX<>OO90 |
VK2IO/P | 18084.0 | 03 Nov 04:35 | VK2IO | WWFF VKFF-1680 |
ZL1RCC | 18100.0 | 03 Nov 02:11 | VK2SOL | tnx/ft8 |
N7PIB | 18100.0 | 03 Nov 02:11 | VK2SOL | tnx /ft8 |
JR6STV | 18100.0 | 03 Nov 01:23 | PY2CAT | FT8 GG66ua -> PL36uf |
KO4RJE | 18100.0 | 03 Nov 01:18 | KO4RJE | EM95VT<>EM95VT |
KO4RJE | 18110.0 | 03 Nov 01:10 | KO4RJE | EM95VT<>EM95VT |
HD8R | 18149.9 | 03 Nov 00:53 | KL7TC | Up 5 calling CQ, not many take |
HD8R | 18150.0 | 03 Nov 00:51 | YV5RAB | 5 up, TU QSO |
HD8R | 18150.0 | 03 Nov 00:48 | NO3K | 5 up |
HD8R | 18150.0 | 03 Nov 00:46 | CX4CJ | SSB, CQ |
XE2YWB | 18100.0 | 03 Nov 00:38 | JM1XRL | TNX QSO FT8 |
HD8R | 18150.0 | 03 Nov 00:01 | JR7FTO | up8 |
HD8R | 18150.0 | 02 Nov 23:59 | JE1GLP | Tnx QSO ! TX18.158 |
HD8R | 18158.0 | 02 Nov 23:57 | JR7FTO | up8 |
HD8R | 18150.0 | 02 Nov 23:51 | G0RNT | |
HD8R | 18150.0 | 02 Nov 23:47 | VE7SNC | listening 18.158 |
HD8R | 18150.0 | 02 Nov 23:46 | VE7SNC | up 8 |
N7ET/DU7 | 18072.5 | 02 Nov 23:27 | W3LPL | Heard in AB |
JR7TKG | 18126.0 | 02 Nov 23:19 | YV1SW | Many thanks Saki fer QSO |
HD8R | 18150.0 | 02 Nov 23:15 | JE1SYN | Up7 |
3W3B | 18100.0 | 02 Nov 23:15 | KW2E | ft8 |
HD8R | 18150.0 | 02 Nov 23:14 | KI4SGQ | |
HD8R | 18150.0 | 02 Nov 23:06 | W3GY | |
HD8R | 18150.0 | 02 Nov 23:05 | WA6DKN | QSX 18157.0 59 |
JF2KMC | 18100.0 | 02 Nov 23:03 | ND4X | FT8 |
JH7OTG | 18100.0 | 02 Nov 23:02 | ND4X | FT8 |
FY5KE | 18075.6 | 02 Nov 23:01 | JA1TOU | CQ |
PJ2MAN | 18140.0 | 02 Nov 23:00 | WA6DKN | 59 |
7N4MRW | 18100.0 | 02 Nov 22:59 | ND4X | FT8 |
7M1HID | 18100.0 | 02 Nov 22:58 | ND4X | FT8 |
FY5KE | 18075.0 | 02 Nov 22:58 | JA1TOU | Tnx! |
JE1SOF | 18100.0 | 02 Nov 22:57 | ND4X | FT8 |
K0YB | 18100.0 | 02 Nov 22:56 | PY4OY | FT8 -10dB from EM28 718Hz |
N7MLR | 18100.0 | 02 Nov 22:55 | PY4OY | FT8 -14dB from EL09 2073Hz |
JF6QWX | 18100.0 | 02 Nov 22:54 | ND4X | FT8 |
HD8R | 18150.0 | 02 Nov 22:54 | KP4PUA | Thanks my friend 54 to PR 73! |
W4TLR | 18100.0 | 02 Nov 22:54 | PY4OY | FT8 -13dB from FM05 965Hz |
FY5KE | 18075.6 | 02 Nov 22:53 | PY1JR | CW |
HD8R | 18150.0 | 02 Nov 22:53 | K6CRC | QSX 18157.0 |
PJ2/KL2A | 18077.0 | 02 Nov 22:53 | PP5BI | tnx qso fb 599 73 dx splx |
FY5KE | 18075.6 | 02 Nov 22:52 | W3LPL | Heard in UT |
HD8R | 18150.0 | 02 Nov 22:50 | K6RLA | 59 AR Tnx |
JJ7ATA/P | 18100.0 | 02 Nov 22:50 | PY4OY | FT8 -18dB 2985Hz |
PJ2/KL2A | 18077.0 | 02 Nov 22:49 | JE5JHZ | CQ simplex |
JA3ADW | 18100.0 | 02 Nov 22:48 | PY4OY | FT8 -13dB from PM74 2356Hz |
JR6STV | 18100.0 | 02 Nov 22:47 | PY4OY | FT8 -18dB 897Hz |
JJ8DEN | 18100.0 | 02 Nov 22:45 | PY4OY | FT8 -22dB 2356Hz |
HD8R | 18150.0 | 02 Nov 22:44 | K3TLP | up5 begging |
W3BLT | 18100.0 | 02 Nov 22:43 | PY4OY | FT8 -15dB from EM73 1891Hz |
JR7TKG | 18126.0 | 02 Nov 22:42 | WA6DKN | 59 plus 10db |
AA6AA | 18073.0 | 02 Nov 22:39 | JG2KJU | TNX CQ STEVE |
N4RWV | 18100.0 | 02 Nov 22:35 | PY4OY | FT8 -17dB 1716Hz |
HD8R | 18150.0 | 02 Nov 22:25 | K4HMF | |
KK6Q | 18100.0 | 02 Nov 22:25 | PY4OY | FT8 -17dB from CM87 2470Hz |
WA9LKZ | 18100.0 | 02 Nov 22:24 | PY4OY | FT8 -14dB from EN62 2355Hz |
VE2CKW | 18100.0 | 02 Nov 22:21 | PY4OY | FT8 -17dB from FN35 2357Hz |
HD8R | 18150.0 | 02 Nov 22:19 | HK6ERU | 5up |
W3GF | 18100.0 | 02 Nov 22:19 | PY4OY | FT8 -19dB from EL87 1324Hz |
HD8R | 18150.0 | 02 Nov 22:18 | KE0L | QSX 18155.00 USB |
KC1NCN | 18100.0 | 02 Nov 22:14 | PY4OY | FT8 -16dB 2514Hz |
CO3VT | 18100.0 | 02 Nov 22:14 | KE8JIT | |
KE6FOA | 18100.0 | 02 Nov 22:13 | VE2ZT | Tnx for nice qso 73 |
K0XMG | 18100.0 | 02 Nov 22:13 | PY4OY | FT8 -10dB from EM17 2355Hz |
N1JTK | 18150.0 | 02 Nov 22:12 | W4SDX | |
C5C | 18100.0 | 02 Nov 22:12 | N3SL | still going |
YV5ZV | 18100.0 | 02 Nov 22:09 | KE8JIT | |
JS6TWW | 18100.0 | 02 Nov 22:08 | N2CG | FT8 PL55 FN20 NJ -08 |
HD8R | 18150.0 | 02 Nov 22:04 | WD9HSY | 1st Call up 5kc |
JS6TWW | 18100.0 | 02 Nov 22:02 | ND4X | FT8 +10 dB into W KY !! |
K4KE | 18100.0 | 02 Nov 21:59 | PY4OY | FT8 -03dB from EM78 647Hz |
W8YKG | 18100.0 | 02 Nov 21:57 | PY4OY | FT8 -18dB from EM78 2354Hz |
JI3MJK | 18100.0 | 02 Nov 21:56 | ND4X | FT8 |
K8EZB | 18100.0 | 02 Nov 21:55 | PY4OY | FT8 -12dB from FN42 2355Hz |
KE7SW | 18100.0 | 02 Nov 21:54 | JM1XRL | TNX QSO FT8 |
W2EKE | 18100.0 | 02 Nov 21:53 | PY4OY | FT8 -10dB from FN13 2354Hz |
K6HXB | 18100.0 | 02 Nov 21:52 | JM1XRL | TNX QSO FT8 |
N7PIQ | 18100.0 | 02 Nov 21:52 | PY4OY | FT8 -13dB from CN88 1858Hz |
JA0CVC | 18100.0 | 02 Nov 21:52 | ND4X | FT8 +01 dB into W KY |
K9UO | 18100.0 | 02 Nov 21:51 | PY4OY | FT8 -17dB from EN70 1968Hz |
JM1XRL | 18100.0 | 02 Nov 21:50 | ND4X | FT8 Nice signal into W KY |
N1RBD | 18090.0 | 02 Nov 21:49 | W6LEN | KFF-0662 |
WD9DZV | 18100.0 | 02 Nov 21:48 | JM1XRL | TNX QSO FT8 |
W9TD | 18100.0 | 02 Nov 21:43 | JM1XRL | TNX QSO FT8 |
HD8R | 18150.0 | 02 Nov 21:41 | JH7KTI | UP 5 59 in N.ja |
W6MVT | 18122.0 | 02 Nov 21:40 | N4AAW | |
N7BUZ | 18100.0 | 02 Nov 21:38 | JM1XRL | TNX QSO FT8 |
W9IIX | 18100.0 | 02 Nov 21:34 | JM1XRL | TNX QSO FT8 |
S0LAR | 18155.0 | 02 Nov 21:30 | ZL2IFB | Flare, a small one |
KN6F | 18100.0 | 02 Nov 21:29 | JM1XRL | TNX QSO FT8 |
HD8R | 18150.0 | 02 Nov 21:28 | KX4UI | 5UP SPLIT |
HD8R | 18155.0 | 02 Nov 21:27 | KX4UI | 5UP SPLIT |
AA2HJ | 18100.0 | 02 Nov 21:25 | JM1XRL | TNX QSO FT8 |
HC3RJ | 18101.4 | 02 Nov 21:23 | N1MHV | |
K6RAH | 18100.0 | 02 Nov 21:21 | JM1XRL | TNX QSO FT8 |
HD8R | 18155.3 | 02 Nov 21:21 | AI6O | |
K5ETU | 18100.0 | 02 Nov 21:20 | JM1XRL | TNX QSO FT8 |
HD8R | 18150.0 | 02 Nov 21:20 | NZ2S | |
FY5KE | 18071.5 | 02 Nov 21:16 | W3LPL | Heard in NH |
C5C | 18100.0 | 02 Nov 21:15 | ND4X | FT8 Nice signal into W KY |
HD8R | 18150.0 | 02 Nov 21:15 | N4WD | cqing needs takers up 5 on spot |
HD8R | 18150.0 | 02 Nov 21:14 | KM4EBT | USB |
WB2RVE | 18100.0 | 02 Nov 21:13 | JM1XRL | TNX QSO FT8 |
W7WHO | 18100.0 | 02 Nov 21:11 | JM1XRL | TNX QSO FT8 |
W6MVT | 18122.0 | 02 Nov 21:10 | KX4UI | POTA K-4575 |
HD8R | 18150.0 | 02 Nov 21:10 | W8LMG | Up 5 Lonely |
HD8R | 18150.0 | 02 Nov 21:09 | K3GWK | UP 5 |
HD8R | 18150.0 | 02 Nov 21:08 | K3GWK | |
CO7MTL | 18100.7 | 02 Nov 21:08 | W1UU | |
PQ2SI | 18100.7 | 02 Nov 21:05 | W1UU | |
HD8R | 18150.0 | 02 Nov 21:02 | KN6CEI | Listening UP 5 |
HD8R | 18150.0 | 02 Nov 20:57 | K3TLP | 5 up begging |
JA0GCI | 18100.9 | 02 Nov 20:56 | N5DPH | EM06MU<>PM96LM FT8 FT8 Sent: +04 Rcvd: -08 |
JE2LSD | 18100.9 | 02 Nov 20:52 | N5DPH | EM06MU<>PM96 FT8 FT8 Sent: -15 Rcvd: -08 |
HC3RJ | 18100.9 | 02 Nov 20:48 | N5DPH | EM06MU<>FI06 FT8 FT8 Sent: -03 Rcvd: -09 |
3D2USU | 18100.9 | 02 Nov 20:46 | N5DPH | EM06MU<>RH82 FT8 FT8 Sent: -17 Rcvd: -11 |
JH1LAH | 18100.9 | 02 Nov 20:45 | N5DPH | EM06MU<>PM96SG FT8 FT8 Sent: -10 Rcvd: -04 |
C5C | 18100.0 | 02 Nov 20:42 | PY2CAT | CCC C5* |
HD8R | 18150.0 | 02 Nov 20:41 | N8AE | |
WP4RBS | 18100.9 | 02 Nov 20:39 | N5DPH | EM06MU<>FK78 FT8 FT8 Sent: +15 Rcvd: +00 |
K8TE | 18100.9 | 02 Nov 20:35 | N5DPH | EM06MU<>DM65 FT8 FT8 Sent: -05 Rcvd: -10 |
HD8R | 18150.0 | 02 Nov 20:34 | K5LG | |
HD8R | 18150.0 | 02 Nov 20:27 | WO2N | UP 5 big Signal! |
HD8R | 18150.0 | 02 Nov 20:26 | W9CY | |
HD8R | 18150.0 | 02 Nov 20:20 | K8MOT | DX PEDITION LISTENING UP 5 |
9Z4Y | 18070.0 | 02 Nov 20:11 | W3LPL | Heard in KY and IL |
HD8R | 18150.0 | 02 Nov 20:12 | K5GET | |
HD8R | 18150.0 | 02 Nov 20:11 | N3NBT | |
HD8R | 18150.0 | 02 Nov 20:10 | AC2PB | 73 Gracias! |
8P6ET | 18100.0 | 02 Nov 20:09 | W6NIF | Tnx 73 from Fresno, CA |
HD8R | 18155.0 | 02 Nov 20:09 | N5FTY | |
HD8R | 18150.0 | 02 Nov 20:08 | KT4O | QSX 18155.00 |
HD8R | 18150.0 | 02 Nov 20:06 | K4SAW | up5 |
HD8R | 18150.0 | 02 Nov 20:04 | W4SDX | |
KB2FMH | 18117.0 | 02 Nov 19:59 | KG0J | |
EC5C | 18100.9 | 02 Nov 19:50 | N5DPH | EM06MU<>IM98 FT8 FT8 Sent: -16 Rcvd: -14 |
CO7MTL | 18100.9 | 02 Nov 19:47 | N5DPH | EM06MU<>FL11 FT8 FT8 Sent: +07 Rcvd: -03 |
HD8R | 18095.0 | 02 Nov 19:46 | XE2NK | DL95UT<>EI59 |
ZS6AF | 18100.9 | 02 Nov 19:44 | N5DPH | EM06MU<>KG54 FT8 FT8 Sent: -06 Rcvd: +03 |
K7UWR | 18102.3 | 02 Nov 19:34 | N5DPH | EM06MU<>EM92 FT8 FT8 Sent: +06 Rcvd: -15 |
XE2ML | 18102.3 | 02 Nov 19:33 | N5DPH | EM06MU<>DL74 FT8 FT8 Sent: -11 Rcvd: -11 |
CE2ML | 18076.6 | 02 Nov 19:14 | PY1JR | CW |
PY1ZB | 18081.0 | 02 Nov 19:13 | PY1JR | CW |
K5KC | 18101.1 | 02 Nov 18:59 | EA4FME | IN80GN<>EM16LC FT8 Sent: -03 Rcvd: -03 |
EA5IPM | 18135.0 | 02 Nov 18:57 | KK6BT | 5-8 in SC |
EA5IPM | 18135.0 | 02 Nov 18:52 | NI4TG | CDM EA* |
TL7M | 18069.0 | 02 Nov 18:46 | HK3W | |
OX3XR | 18085.0 | 02 Nov 18:45 | W3LPL | Heard in NH and KY |
OX3XR | 18082.3 | 02 Nov 18:45 | W3LPL | Heard in NH and IL |
HD8R | 18094.0 | 02 Nov 18:44 | EA1DSK | FT8 |
HD8R | 18095.0 | 02 Nov 18:39 | EA5GHD | -14 F/H |
7P8RU | 18076.0 | 02 Nov 18:21 | K5GET | |
LU4JHF | 18083.8 | 02 Nov 18:15 | EA1ARW | CQ |
HD8R | 18096.0 | 02 Nov 18:13 | EA1DV | FT8 -13 IN81DQ<>EI49KD |
7P8RU | 18076.0 | 02 Nov 18:13 | K9GTH | 599 into CT |
EI5DS | 18081.0 | 02 Nov 18:12 | K5KV | |
7P8RU | 18076.0 | 02 Nov 18:11 | W8ASA | Loud into Dayton Ohio |
HD8R | 18095.0 | 02 Nov 18:10 | WB5TUF | F/H FT8 |
HD8R | 18095.0 | 02 Nov 18:10 | EA7TR | FT8 FH |
7P8RU | 18076.0 | 02 Nov 18:06 | EA1ARW | CQ -- UP |
7P8RU | 18076.0 | 02 Nov 17:59 | W3LPL | Heard in NJ and TX |
CO7FR | 18088.0 | 02 Nov 17:55 | F2IL | TKS FR QSO 73 |
7P8RU | 18087.0 | 02 Nov 17:53 | W3LPL | Heard in CO and AZ |
LZ5QD | 18102.5 | 02 Nov 17:42 | N5DPH | EM06MU<>KN12 FT8 FT8 Sent: -15 Rcvd: -20 |
CT9/DL3KWR | 18086.8 | 02 Nov 17:37 | PY2KS | TU 73 |
N4IRK | 18102.5 | 02 Nov 17:37 | N5DPH | EM06MU<>FM16WS FT8 FT8 Sent: -11 Rcvd: -24 |
HD8R | 18095.0 | 02 Nov 17:37 | N2LQ | F/H FT8 |
N4IRK | 18102.5 | 02 Nov 17:37 | N5DPH | EM06MU<>FM16 FT8 FT8 Sent: +17 Rcvd: -24 |
EB1EA | 18150.0 | 02 Nov 17:37 | IK6FBB | tnx for qso 73 luigi |
AF5EH | 18100.0 | 02 Nov 17:35 | DL4MFF | JN57IW<>EM12HW tnx ft8 |
IK5BCM | 18102.5 | 02 Nov 17:31 | N5DPH | EM06MU<>JN53 FT8 FT8 Sent: -11 Rcvd: -24 |
7P8RU | 18087.0 | 02 Nov 17:28 | EA2DPA | Up |
7P8RU | 18087.0 | 02 Nov 17:23 | LA6UOA | TU!! NICE! CQ CQ! |
IZ4TNN | 18102.5 | 02 Nov 17:22 | N5DPH | EM06MU<>JN54 FT8 FT8 Sent: -02 Rcvd: -11 |
OY1CT | 18068.6 | 02 Nov 17:19 | W3LPL | Heard in NH |
G0KPH | 18102.5 | 02 Nov 17:18 | N5DPH | EM06MU<>IO92 FT8 FT8 Sent: -07 Rcvd: -11 |
UA1OIZ | 18102.5 | 02 Nov 17:17 | N5DPH | EM06MU<>LP04 FT8 FT8 Sent: +00 Rcvd: -21 |
HD8R | 18140.0 | 02 Nov 17:16 | IZ0ZAD | Tnx for contat 73 up5 |
7P8RU | 18086.9 | 02 Nov 17:13 | NA5YO | |
7P8RU | 18087.0 | 02 Nov 17:12 | WA8Y | Up 1 |
HD8R | 18145.0 | 02 Nov 17:12 | G0GDA | Mni tnx |
G4CEP | 18101.7 | 02 Nov 17:09 | N5DPH | EM06MU<>IO92UD FT8 FT8 Sent: -15 Rcvd: -15 |
G4CEP | 18101.7 | 02 Nov 17:08 | N5DPH | EM06MU<>IO92 FT8 FT8 Sent: -08 Rcvd: -15 |
HD8R | 18140.0 | 02 Nov 17:08 | EC5KY | tnx 73 |
G8CVS | 18101.7 | 02 Nov 17:07 | N5DPH | EM06MU<>IO91 FT8 FT8 Sent: -17 Rcvd: -07 |
N6MKW | 18092.0 | 02 Nov 17:06 | W6LEN | KFF-5149 |
HD8R | 18140.0 | 02 Nov 17:04 | NK9G | |
7P8RU | 18087.0 | 02 Nov 17:02 | G3JNB | At last! 12 watts vertical |
7P8RU | 18087.0 | 02 Nov 17:01 | EA3B | CW |
HD8R | 18140.0 | 02 Nov 17:01 | KB6LFM | listening up 18.145.00 |
7P8RU | 18087.0 | 02 Nov 16:59 | PA0CIS | QSX 18088.1 |
7P8RU | 18087.0 | 02 Nov 16:58 | PY2FSR | tnx up 1 |
7P8RU | 18087.0 | 02 Nov 16:57 | NK9G | |
7P8RU | 18086.8 | 02 Nov 16:57 | NA5YO | CQ CQ |
HD8R | 18140.0 | 02 Nov 16:55 | EA3HSO | QSX 18145 |
7P8RU | 18087.1 | 02 Nov 16:54 | WB2WFJ | UP |
7P8RU | 18087.0 | 02 Nov 16:53 | W3LPL | Heard in NH |
CT9/DL3KWR | 18086.8 | 02 Nov 16:50 | DL3KUD | YL Rosel |
EA8ED | 18167.0 | 02 Nov 16:49 | EA8RKL | Faros TENERIFE y LAS PAMAS |
CN8ZG | 18135.7 | 02 Nov 16:44 | IZ7QEN | 58 CIAO |
W2AMC | 18100.0 | 02 Nov 16:40 | F1DSZ | FT8 -01dB from FN31 754Hz |
N1UL | 18100.0 | 02 Nov 16:40 | PA5WK | tnx 73 |
CN8ZG | 18135.7 | 02 Nov 16:37 | I4EWH | cq |
HD8R | 18140.0 | 02 Nov 16:36 | IK2TCV | 73 tnx up5 |
KD4RAA | 18100.0 | 02 Nov 16:35 | PA5WK | tnx 73 |
CN8ZG | 18134.0 | 02 Nov 16:35 | EC3AAJ | HASSAN |
HD2R | 18140.0 | 02 Nov 16:35 | W3AZT | SPLIT UP 5 |
EA2EBS | 18100.0 | 02 Nov 16:34 | ES5QA | KO38CS<>IM99 |
CN8ZG | 18133.7 | 02 Nov 16:34 | I4EWH | corr call |
HD8R | 18140.0 | 02 Nov 16:34 | PA0CIS | QSX 18145.0 sri |
CN8ZF | 18133.7 | 02 Nov 16:34 | I4EWH | cq |
HD2R | 18140.0 | 02 Nov 16:33 | PA0CIS | QSX 18145.0 |
EA3NG | 18100.0 | 02 Nov 16:33 | SP5NOF | FT8 -01dB from JN01 740Hz |
GD0OUD | 18074.8 | 02 Nov 16:32 | W3LPL | Heard in MD |
ES5QA | 18100.0 | 02 Nov 16:32 | SP5NOF | FT8 -22dB from KO38 934Hz |
DF2BO | 18130.0 | 02 Nov 16:31 | WN3T | looking for NA west coast |
MM5AJN/M | 18160.0 | 02 Nov 16:30 | EA3CC | 73, |
OX7AM | 18091.0 | 02 Nov 16:29 | DL5XN | tnx, loud sig |
N0NWY | 18100.0 | 02 Nov 16:28 | PA5WK | tnx 73 |
HD8R | 18140.0 | 02 Nov 16:26 | IZ7QEN | 59 CIAO |
HD8R | 18140.0 | 02 Nov 16:26 | F8ASG | |
OX7AM | 18090.0 | 02 Nov 16:24 | EA4FW | S5 IM76gc NE/SW IV-G5RV 10m up |
ND6H | 18100.0 | 02 Nov 16:23 | PA5WK | tnx 73 |
HD8R | 18140.0 | 02 Nov 16:23 | PC9DB | up5 |
PA0WDN | 18101.7 | 02 Nov 16:21 | N5DPH | EM06MU<>JO22 FT8 FT8 Sent: -04 Rcvd: -11 |
SP1O | 18101.7 | 02 Nov 16:19 | N5DPH | EM06MU<>JO73 FT8 FT8 Sent: -03 Rcvd: -11 |
HD8R | 18140.0 | 02 Nov 16:11 | SV1GFM | Tnx 73 |
OX7AM | 18092.5 | 02 Nov 16:19 | N2YBB | |
ON4CBK | 18101.7 | 02 Nov 16:18 | N5DPH | EM06MU<>JO11 FT8 FT8 Sent: -04 Rcvd: -07 |
F6BCW | 18070.0 | 02 Nov 16:18 | WB8SCT | |
DG3NCZ | 18101.7 | 02 Nov 16:15 | N5DPH | EM06MU<>JO50 FT8 FT8 Sent: -02 Rcvd: -04 |
7P8RU | 18088.0 | 02 Nov 16:14 | N2YBB | |
EA3FZT | 18070.0 | 02 Nov 16:14 | WB8SCT | |
IK8HIS | 18101.7 | 02 Nov 16:12 | N5DPH | EM06MU<>JN71 FT8 FT8 Sent: +04 Rcvd: -14 |
PJ2/G4XUM | 18078.1 | 02 Nov 16:12 | N2YBB | |
DJ7JB | 18101.7 | 02 Nov 16:11 | N5DPH | EM06MU<>JO62 FT8 FT8 Sent: -15 Rcvd: -24 |
7P8RU | 18088.6 | 02 Nov 16:11 | W9MO | up |
OX7AM | 18090.9 | 02 Nov 16:10 | SP2DKI | QSX UP |
OX7AM | 18091.0 | 02 Nov 16:10 | WB9DLC | |
ON7FR | 18101.7 | 02 Nov 16:09 | N5DPH | EM06MU<>JO11 FT8 FT8 Sent: -15 Rcvd: -15 |
LY5M | 18070.0 | 02 Nov 16:08 | WB8SCT | |
OX7AM | 18091.0 | 02 Nov 16:06 | W5ETL |
